Good Flame
armed with a proper digital combustion analyzer. The readouts will determine whether you have a good flame.
Sounds like these units are oil-fired. A modern flame-retention oil burner, properly selected, installed and adjusted, will NOT generate soot. Ask me how I know that......
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • biglou
    biglou Member Posts: 3
    I want to know what a good flame in a boiler or hwh is. Examples:
    Weil Mclain 3-section- where should the flame look like and where should the flame tips be
    American standard with square box chamber how should the flame be in that unit
    Bock 32gal. Hwh how should that flame look.
    Light soot in the boiler and smoke pipe means too rich or too lean.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    flame????
    don't even think about adjusting the flame. From the way you phrase your questions, (no offense ) you aren't in the business, right? You simply can't adjust a flame by eye. It takes special instruments to do the job safely and correctly. Your health and safety are in jeopardy if you attempt to do this work yourself without the proper tools and experience. Hire a pro for this work...he can change that flo check at the same time.
