Heat Exchangers
S Davis
S Davis Member Posts: 491
What brand of heat exchangers do you guy's use for swimming pool heating?
S Davis
Apex Radiant Heating
  • will smith_2
    will smith_2 Member Posts: 49
    The problem with heat exchangers around pools is that all too often, the combustion air is drawn from around the pool area. Chlorine will eventually eat a heat exchanger alive (kinda makes you wonder about us!) If you have a system totally isolated from the pool (taking combustion air from elsewhere), you should get more life out of your heat exchanger.
  • S Davis
    Heat Exchangers
    I guess I should have been more clear, I mean for heating swimming pool water from a boiler.
    S Davis
  • will smith_2
    Well, the wall may prove me wrong, but I guess I'd feel safe with cast iron. You'd still have fits if the combustion air is drawn from around the pool.
  • Einsiedler_2
    Einsiedler_2 Member Posts: 93
    pool H.E.
    if it is a salt water pool - you MUST use titanium. Otherwise a stainless will suffice.
    I like the Seces-Pol Line (B-Series)
    www.secespol.com
    whatever you do - DO NOT use cast iron... or anything close to ferrous.
    cheers!
    EIN
  • hr
    hr Member Posts: 6,106
    I think he is looking
    for an indirect type of heat exchanger to run off a boiler in another location? I have used the Triangle Tube and Weil Mclain, possibly the same brand.
    hot rod
  • marc
    marc Member Posts: 203
    flat plate
    marine grade exchangers, have worked very well for us. marc.
  • marc
    flat plate
