biogas
Glen
Member Posts: 854
the JB3 was put back into service - it made all the bugs in the 12 000 000 gal tank happy. so if I am firing at 8 500 000 btuh on nat gas - I would be about half that for the other gas??? It's a difficult burner to do that - as I can set gas separately but not the air - might make for some intersting flue gases! the system was too cold today to crank up the digester - so we have to wait! And JB 3's like it just so on light off! Fortunately I light off on nat gas and then switch to bio on the main gas. Next visit will be more interesting!
looking for calorific content
For biogas produced in a high temp anaerobic process. Need to program my analyser for a "user fuel" designation. Any ideas? Or do I have to have a lab analysis for methane/carbon dioxide/ hydrogen sulphide content?? Utility is resurrecting a Volcano boiler to preheat the composting/digesting material. Burner unknown at this point - will find out tuesday morning. kcal/kg would be the most useful measurement.0 -
Nooooooo...
there is no " Content"
that is repeatable
figger 500 butes/ cu ft0 -
bye the bye ..
we call it ." **** Gas "0 -
that is -
only one of the names I heard it called at the pant the other day. So on avg - then is it 50% methane?0 -
glenn ...
the btu content can vary a LOT...
but not more than, say 500 butes/cf
it is mostly ...
nitrogen
water
sulphur
grit
with something flammable mixed in
I do a LOT of **** Gas work0 -
Ooooohh ..
just read the "anal-yzer" part
fergit that ..!!!0 -
so then -
no testing for flue gases. that's posivitvely anal. :-)0 -
you can measure yer O2
that is a good figger
all the other calculations will be wrong0
- 120 Geothermal
