Dole valves
Alan_6
Alan_6 Member Posts: 87
Does anyone know where I can purchase a good quality dole key? One that is made with steel, 3/16 square head, for purging the old coin vents on radiators. I have found some cheap ones at hardware stores, made from a light metal, but they split after a short time. Or does anyone know where a socket this size may be? Thanks.
  • Dave Bush
    Dave Bush Member Posts: 155
    Check with Sears
    A Sears hardware store might be better. There used to be "* point" sockets available, for square heads. I THINK that the set went down to 3/16, but I'm not positive.
  • Woody
    Woody Member Posts: 34
    dole valves
    suggest you contact our office and we will send you same as we represent dole valves.
  • Alan_6
    How do I contact your office? Thanks
