Dole valves
Alan_6
Member Posts: 87
Does anyone know where I can purchase a good quality dole key? One that is made with steel, 3/16 square head, for purging the old coin vents on radiators. I have found some cheap ones at hardware stores, made from a light metal, but they split after a short time. Or does anyone know where a socket this size may be? Thanks.
Check with Sears
A Sears hardware store might be better. There used to be "* point" sockets available, for square heads. I THINK that the set went down to 3/16, but I'm not positive.0 -
dole valves
suggest you contact our office and we will send you same as we represent dole valves.0 -
How do I contact your office? Thanks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
