Clammy munchkin install
clammy
Member Posts: 3,251
Many thanks for the kind words ,i've found that as with hot air 90 plus furnaces upsizing the venting really quites down the noise levels outside plus they did not have the v500 kit so i saw the v1000 kit and scafed it up ,i'm a little up in the air wih the hydro seperator it in no way removes air like a spriovent just doesn't but it does seemingly use less space then proper primary secondary piping and that's if you are following the rules you know 8 pipe diameters of straight pipe on the inlet and outlet of your closely spaced tee but if you follow the rules all the time i've been able to pipem with a sprovent and my 2 tee in just about the same amount of space so still don'tsee all the benefit but it did go alot quicker then i expected .Again thanks for the kind words unless there my jobs i always get the feeling that i'm taking to long or there is no money in for extra valves ,supports aside from run of the mill stuff but using drywall screws instead of real hardware sorry for the rant peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
This is install is in my own house it's a t80 wall hung with a vision one kit for domestic hot water i used my favorite a buderus st150 tank with a taco 5000 mixing valve i also got sold into a califee hydro seperator .As for heat emmitters i have slant fin 30 and a small fan coil unit for the basement .It was alot of work from framing the wall ,insulating ,rocking and then the fun began .All in all it took about 50 hours to get it to this stage but i was working alone and still have a couple of clamps and hangers to install ,she is running like a champ heating my home running at about 130 with the max set up for 165 ,peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
B.E.A.utiful
If all my jobs were designed and installed like this I would be out of the serviceman buisness.
Love the DPB valve BTW... by far the most underused hydronic solution in my opinion.0 -
Blk pipes's.....Nice
Sweet looking piping job Clammy, clean, stright and Blk. Now thats a system that will last a long time, i see you like the st tank from buderus, nice job Sir!!
David0 -
Nice!!
Nice piping. Accessible with all components isolated. I'm surprised you didn't use the Buderus GB wall hung. Any reason for the preference?
by pass
Excellent Job, Clammy why the by pass around the feed regulator,and do you use it on all your installs.0 -
by pass
Thanks
Thanks for the very kind words .I have been a little busy and really have not posted quite a few jobs and a few that i had no camera for there where a few munchkins and a few steamers and CI water boilers amonug a couple of whole house plumbing ,heating and a/c jobs but this is the last one for the year i will be leaving the country this week for a month or so to be with my wife for the holidays that's why i have been workin like a beaver but when i return there shall be alot more jobs lined up and ready to go and all will look better then the last ,I love buderus stuff except with a price about double of a munchkin it did not fit my budget but being a nutty wet head who knows i could change her out in a year or two i doubt .I did have one promblem room a small office former garage with not enough base so i cut n a old cast rad now it's beautiful wish i had cast every where again thanks for the kind words but it's your fine work that drives me to make pipe work a art form peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
beautiful in black!!!
Nice pipework Clammy!!
So when did the wife say... "That's gonna cost us WHAT!!!!"
BTW, is that the LWC I see in green on the system side of the Caleffi separator?
Cosmo0 -
Clammy, that is the nicest install I've seen on the wall in awhile. Unbelievable attention to detail, I really like the use of steel, it looks so much more professional. As always keep up the good work bro!
yes and yes
Yeap the lwco is on the supply side and i always try to install a feed by pass less wear and tear on the prv and allows you to really fast fill and purge with some pressure plus late at nite it's better then a washer machine hose off the hot water tank and the wife well she not in this country right now but if she was she would not say a thing she knows im nuts i think thats what she likes about me the pdv was finally delivered after complaining for over ten years the new hydronic design guy knew what i was talkin about he called the local reps who finally knew what i was talkin bout and handed me a PO and off to the local itt supply guys and picked it up and that's that now that i can finally get em on my return home they will become a stock item they are wonderfull devices and work a billion times better then a manual by pass that does not adjust to syetm flow differences .Again thanks for your kind words it's your best work that drives me to produce the work i do .I hope one day to be as good as you guys when i grow up peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Clammy
That is one A-1 install! Nice colors, paint job, finish. The Caleffi alone is worth the price of admission.
Thanks for posting! I am inspired to do better, not that I could. But it is an install to aim for.
Brad0 -
Clammy nice job.
I love my Gb-142. It is not the product as much as taking pride in the installation. You take a lot of PRIDE in your work.
Thanks
Ray M
Comfort Tech Corp0 -
Clammy rules!
Why don't you live in the Toronto area? I love the look of black iron and you do the tightest installs. That would drive many batty - measuring threaded is an art not a science. That Caleffi looks so at home - the black on black is so chic - nice when the boiler matches as well!
Very inspiring for us piping junkies.
Did you consider the 2" option for the venting?0 -
munchkin install
A wonderful job,a truely beautiful planned out execution.0 -
Great job, Clammy!
All that uninterupted black pipe speaks volumes about your ability to anticipate how long each piece needs to be, how to tie them together, etc. It's awe inspiring. The Caleffi bottle is a really nice touch also. As usual, these customers are lucky to have you as their contractor.0 -
Clammy...
Thanks for keeping Tradition alive.
Outstanding installl.
Have a safe trip.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Speaking of bypasses...
I really like the bypass for the domestic hot water mixing valve off the back of the Buderus indirect. Very nice!0 -
clammy
Very nice looking job.
Robert O'Connor/NJ0 -
That,.. is Very Clean
i have looked at this many many times ...the more i looked at it the more appreciation i had for it,....i am glad it has stayed here ,i am running out of book mark spaces:)0 -
I'll bet the customer thinks the \"BLUE\" thing is the boiler
It's funny to look at since the Boiler is 1/3 size of the indirect. The customers must be thinking that they paid what for that little Box on the wall. It's nice to see that type of setup when Oil systems are the norm for me. Very nice work Clammy as David stated.
Rich0 -
that there is one great
installation..your work is awe inspiring Clammy..you got to quit raising the bar so high, cause its hard to catch up.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Outstanding!
I can just see my Dad and all of the other Dead Men smiling!0 -
Thanks to all
Thanks to all for the inspiring words of kindness and every job i do i hope that somewhere better some dead gys are smiling down with dirty hands and chewed up finger nails and knuckles .Hope everyones holidays are safe and healthly and be posting again next years as allways have some peace and alot of good luck clammy and also i want to thank our most excellent host Mr Dan H for offering us the chance to see other fine work and give so much back to us all thanks Dan you RULER.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Workmanship
awesome job as usual.
Did you find that the stock in all black was less expensive than the copper?
Massachusetts
Wow
Clammy,
Like art, as usual.0
