radiant heat copper tube leak
ED MILLER
Member Posts: 3
Cust. has radiant heat copper tube with a leak any chemicals I could pour in
Anything one would inject
I would take as a temporary fix... but will admit to having temporary fixes still in place 25 years later....:)
Can the leak be identified for size and location for a proper (brazed) repair?
Anyway, here is a line of products you might consider:
http://www.silverkingmfg.com/0 -
Brad's right on
I've had good luck with the silver king safe, especially on near-boiler and exposed piping. Seems to be permanent (so far anyway). Under the floor I would never guarantee any kind of stop leak, although it might work. I farm out leak detection to guys with fancy equipment, including the killer; infra-red imaging. Identifies the piping lay-out, leaks, etc. I don't change my oil anymore either. Good luck.0
- 167 Indoor-Air Quality
