radiant heat copper tube leak
ED MILLER
ED MILLER Member Posts: 3
Cust. has radiant heat copper tube with a leak any chemicals I could pour in
  • Brad White_91
    Brad White_91 Member Posts: 25
    Anything one would inject
    I would take as a temporary fix... but will admit to having temporary fixes still in place 25 years later....:)
    Can the leak be identified for size and location for a proper (brazed) repair?
    Anyway, here is a line of products you might consider:
    http://www.silverkingmfg.com/
  • Jerry_15
    Jerry_15 Member Posts: 379
    Brad's right on
    I've had good luck with the silver king safe, especially on near-boiler and exposed piping. Seems to be permanent (so far anyway). Under the floor I would never guarantee any kind of stop leak, although it might work. I farm out leak detection to guys with fancy equipment, including the killer; infra-red imaging. Identifies the piping lay-out, leaks, etc. I don't change my oil anymore either. Good luck.
