pipe insulation
Brad White_91
Member Posts: 25
as a concern, no. What is your concern with regards to the 3/4" strut?
I visited a building whose condensate lines leading to a floor drain have soaked the fiberglass insulation with condensate and is puddling the floor. The 1 1/2" condensate header is sitting on top of 3/4" strut on the floor.
I was thinking of repiping the header to sit on top of 1 1/2" strut and installing 1" thick foam insulation.
Any recommendations?0 -
Copper or Plastic?
Sounds like a choice at the grocery checkout. (Copper please!) 1 1/2" is not cheap in the latter..
If PVC, that it would sweat that much is unusual in my experience but if you are running a Unico or other HV system the condensate will be in the low-mid 40's. If copper that definitely would sweat. Are you sure it is external condensation? Or a leak?
If condensation almost any thickness of Armaflex should work provided it is not in a completly muggy, unconditioned area. If so, use a full 3/4", sealed. Regardless of thickness, make sure it runs continuously through the hangers, no stopping. Insulated clamps are also a good idea.
Big drain, 1 1/2", how many tons?0 -
Don't know how many tons, but the piping is copper. Large building. Think I could keep the 3/4" strut?0 -
A picture would be great.
You can use armofllex insulation and possibly add a trap at the unit to stop the rush of cool air thru the condensate line if not already trapped,
Mike T.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
