Vacuum drying firewood
LarryC
LarryC Member Posts: 330
I am toying with the idea of using vacuum to dry firewood faster. My thought is to use an old piston refrigeration compressor as the vacuum source and a 3 foot diameter 2 foot tall concrete pipe as the chamber. Cement the chamber to the floor and make a suitable lid.
It is my understanding that if I draw too deep of a vacuum too fast, the water in the wood would freeze. So I would have to be able to slowly introduce the vacuum in order to draw the water out.
Wadda ya' think?
Larry
  • Weezbo
    Weezbo Member Posts: 6,231
    it sounds like you could distill the water and sell it as
    > It is my
    > Wadda
    > ya' think?
    > Larry
  • Weezbo
    > It is my
    > Wadda
    > ya' think?
    > Larry
  • Ken_40
    Ken_40 Member Posts: 1,310
    Brilliant idea!
    However, the energy expended to pull an appreciable vacuum will accelerate your electric bill more than the reduced time required to "season" the wood faster than "air-drying" would allow?
    How long and, how much of a vacuum do you suppose it would take to "boil" and extract the water trapped in the center of the log, 2-12" from the outer layer(s)?
    Interesting concept nonetheless!
    Just remember, when we vacuum an A/C system, we are dealing with metal tubes, not pithy fibers 2' long X 6" diameter (;-o)
  • Weezbo
    Mr. Larry's Magic elixer *~/:)
    sell it to posh up town bistro's "for Cooking purposes only' :)
  • LarryC
    Pre-oiled water for the ultimate pasta chef.
    How long and how deep? Don't know. My guess (wish) is less than 24 hours if I start with semi seasoned split wood. We recently had a chimney cleaning and there is evidence of a slow burning chimney fire and excessive creosote build up. While we are waiting for the insurance company and then rebuild the chimney, I figured I would look at alternatives to prevent this from happening again.
    I could rig up a sensor to one of the logs to measure moisture content and make the system semi-automatic.
    Larry C
  • Weezbo
    There it is! *~/:)
    unbounded awareness :)
    for the commonly uncommon palate....
    remember me when you strike it rich :)
  • joel_19
    joel_19 Member Posts: 933
    Also
    Concrete and wood are both hydroscopic meaning water vapor can move thru the concrete. i would think you would need to waterproof the concrete with something
  • LarryC
    Waterproofing
    If the system works, then I can seal the outside of the concrete with a suitable finish. Or if the migration is slow enough, ignore it.
    Larry C
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Solar is the way to go
    Don't have links, but have seen plans for solar kilns, wood dryers, etc.
  • Perry_2
    Perry_2 Member Posts: 380
    Some heat will go a long way too...
    add heat to the mix for better results. Water boils at 92 F at 30" Hg vacuum.
    However, from a cost of construction and energy bill concept - A solar dryer is probably the way to go.
    Of course, if you let the wood season a year or two it naturally dries out. Very low energy cost. All you need is the space to store the wood for a season (or buy seasoned wood).
    Perry
