Buderus LT160 HotWater
RoosterBoy
RoosterBoy Member Posts: 459
hi what is the difference between the L160 and the LT160
I will be using the G115 28 with 2109 controller
thanks
  • Mike Kraft_2
    Mike Kraft_2 Member Posts: 400
    The difference
    The LT is to park under an oil fired and the L series is for under the gas fired.Other than that they are both 42 gallon and one of the top tanks that money can buy.
    cheese
  • Joe@buderus
    Joe@buderus Member Posts: 165
    L and LT Tanks
    What Mike stated is true. The LT Tank comes with a bracket to mount the G115 Boiler to it (a bracket kit has to be ordered to mount a G215 boiler).
    The L series tank is provide with two studs which line up with the gas boiler bottom bracket.
  • RoosterBoy
    hi joe with my elictric rate at 0.727kwh i am running elctric now would the lt160 with g115 be still cheeper to run
    then elctric hot water
  • dconnors
    dconnors Member Posts: 215
    electric vs oil
    My best info says electric would have to be about 4 cents per kilo to equal oil. hope this helps. maybe someone else has more current info
