Is the Vitola 200 overkill?
Why don't you leave it and tell what you've found?
This is an on-line community where people help people.
  • jknight
    jknight Member Posts: 5
    _EDIT_
    found good answer with search - nevermind
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    If
    you mean other boilers will do the same job for less money? Yes,they will.But the Vitola is the ultimate in Quality,Engineering and Materials for oil-fired boilers for any temp application.The Vitoflame burner and Vitotronic controls are in a class by themselves. You don't need a Mercedes either but it's sure a nice way to go!
  • Weezbo
    Weezbo Member Posts: 6,231
    why not two *~/:)
    with a new control from Viessmann that does lagg lead And rotation ?:) Hint hint :)
    ok. so there isnt a rotation control i would just like to have one...i admitt it. just rolling it by the powers that be.
  • Kevin__Flynn
    Kevin__Flynn Member Posts: 74
    Weezbo your dream has come true.
    You would use a Vitotronic 333 on the wall with a Vitotronic KK10-LON on each Vitola, or Vitogas. This strategy is good for up to (4) boilers, and yes with rotation.
    Kevin Flynn
  • Weezbo
    Thank you *~/:)
    that is so good:) my appreciation Kevin .
