Is the Vitola 200 overkill?
Jeff Lawrence_24
Member Posts: 593
Why don't you leave it and tell what you've found?
This is an on-line community where people help people.
_EDIT_
found good answer with search - nevermind0 -
If
you mean other boilers will do the same job for less money? Yes,they will.But the Vitola is the ultimate in Quality,Engineering and Materials for oil-fired boilers for any temp application.The Vitoflame burner and Vitotronic controls are in a class by themselves. You don't need a Mercedes either but it's sure a nice way to go!
why not two *~/:)
with a new control from Viessmann that does lagg lead And rotation ?:) Hint hint
ok. so there isnt a rotation control i would just like to have one...i admitt it. just rolling it by the powers that be.0 -
Weezbo your dream has come true.
You would use a Vitotronic 333 on the wall with a Vitotronic KK10-LON on each Vitola, or Vitogas. This strategy is good for up to (4) boilers, and yes with rotation.
Kevin Flynn
Thank you *~/:)
that is so good:) my appreciation Kevin .0
- 167 Indoor-Air Quality
