minisplit systems
ed wallace
Member Posts: 1,612
ok the install manual shows copper tubing attached to indoor unit from the factory then it shows how to make flare fittings and insulate them and cover with tape the tubing exits the wall 7 ft below and 4 ft to left of indoor unit where exposed the lines are not insulated
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
mini split systems
can ahny one tell me why refrigerant lines on mini split systems should be insulated I looked at at a 3 month old LG system tonite where the lines are not insulated where exposed and refrigeration tubing is in a wall so there is no way to check the flare fittings
It depends!
If the metering device is in the condenser-insulate! If the metering device is in the evap-insulate only the Suction!
I have installed both ways, don't have a favorite.
Do remember correcting two Carrier mini-split HP that the orfice was in backwards. Took two summers to figure one out. By the time the other one was found-dead compressor!
Don in MO0 -
mini's
Hello! Can you describe what is meant by "flare fitting in the wall" ? Are the refrig lines insulated where "not exposed"?Enjoy!0 -
MINI'S
Hay! Thats mini's!Just make a good tight connection!6lb's in a 5 1/2 bag I think! But they are what they are!!!!!!!
Most have the metering device in the outdood unit so insulate all the way.Enjoy!0
