Instrumentation of existing Manual Valves
Josh_10
Member Posts: 787
Are you trying to retro-fitt existing valves or replace them?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=434&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Valve position
I have several hundred existing manual valves (Mostly globe valves) that I need to instrument to determine the actual valve position. In an ideal world it would nice to have a 0-10 volt output representing valve position. The output of these valves will be connected to a computer system.
I also have some butterfly valves0 -
Nothing unusual
This is done all the time, Richard. Most DDC systems have feedback valve position data as a function of their proportional signal.
Just do not confuse this with valve "output" for globe valves are anything but linear. 50% open might mean 90% of flow for example.0 -
Fair point, Josh...
I missed the obvious point that he has existing globe valves while control-type globe valves use a piston-type stroke, not a rotary one. I suppose you could still get actuators of the rotary type with proportional I/O's... What do you think?0 -
Well I guess it depends on alot of things I guess. Brands, types, and how much work one is willing to put forth. Sounds like alot of work either way!
I am curious though as to what our friend is doing! Can you explain the project? Seems like quite an undertaking. Are you trying to get a proof of closure for the valves or measure flow? Perhaps differential pressure orifice type sensing devices might serve your purpose better?
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
