Buffer tanks???
joel_19
joel_19 Member Posts: 933
I had a Buffer tank made for us custom by a local company that makes water heaters. it's Stainless Steel 1.25" taps well insulated and looks like an indirect sans internal coil in 40 gallon size.
Had it made for a special project we where working on as I couldn't find a suitable one from the typical suspects.
Soooooo now I'm wondering if we built more of these is there much of a mrket out there . Who's been looking for something like this?? Can't be just me??
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=254&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Joe Brix
    Joe Brix Member Posts: 626
    Stainless steel?
    Overkill for a buffer tank.
    Commercial jobs probably needs ASME certification.
    I'd think it's probably cheaper to buy a reverse
    indrect and remove the coil.
  • WaterHeaterGuy
    WaterHeaterGuy Member Posts: 80
    Heat Transfer Products manufactures a stainless buffer tank too... although they have 1 1/2" tappings.
    As for a reason to make it stainless... non-oxygen barrier tubing comes to mind.
  • Joe Brix
    True
    But you're talking abou their booster tank right?
    A 40 gal unit only has 3/4 tappings. I think you have to go to an 80 gal tank for the 1.5" tappings and you only get 3.
  • joel_19
    Stainless
    It's not really that much more $$$ and this particular company already fabs stainless tanks no chance of rust works for me barrier tube or not.
