oiltank in garage
Cosmo_3
Member Posts: 845
Maybe worth a call to the inspector. I do that a lot and it has saved me big bucks. Sorry buddy I didn't want to imply that you were not going to get a permit, just that it is up to Mr. Inspector so maybe ask him.
JCA, that setup looks neat!
Cosmo
Cosmo
what are the nfpa31 regs...
on placing a 275 gallon oil tank in a residential garage....I have a copy of nfpa 31 but can't find any references as to any special set ups...some towns want cement lally collums in front of tanks but again I cannot find any references to it....ty, kpc
Last time I was involved with a residential garage oil tank install the municipality wanted two 4" schedule 40 steel pipes installed as pilings in front of the tank. 3 feet under ground, 4 feet above, filled with concrete. Thankfully the customer ended up taking care of the pilings himself.
I also looked at the NFPA31 book, and don't really see much mention of a residential garage installation specifically. Is there a permit? Ask the inspector what he recommends. Personally I would feel okay with the pilings, as long as there is no where else the tank could go.
Cosmo0 -
there will ...
be a permit....now I am pricing out the job....kpc
NFPA 31...
Says the tank MUST BE PROTECTED. That's about it !. This is where it gets a bit hairy. Like Cosmo said, some inspectors want cement filled lally columns 3' into the concrete, while othes feel that lagging them to the floor is fine.
I did this job in a town close by. The inspector loved it, and Firedragon uses the photo in his classes. All criteria have been met. The tank is in a 3 bay "truck garage", where they do PM for a landscpe and land contracting company. Since these photos were taken, I've also added the same 2" black iron w/ flanges set-uo to their diesel fuel tanks which are just infront of this 275. Chris0 -
Nice job. And I'm sure it's easier than trying to drop in lollies.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
