LLH Dimensions
Uni R
Uni R Member Posts: 663
*bump*
  • Uni R
    LLH Dimensions
    Does anyone have the dimensions for the two smaller Viessmann low loss headers? LxWxD with and without insulation and even more important the distance between centers for each side and the standard fitting sizes? Thanks...
  • Ted_5
    Ted_5 Member Posts: 272
    LLH sizes
    the 80/50 H 22" W 3.1" the connections stick out 4" so overall W 11.1" connectios are 1 1/4".
    the 120/80 H 36" W 4.7" The connectios stick out 4" so overall W 12.7" connections are 2"
    Ted
    WI. Viessmann rep.
  • Uni R
    Thanks Ted - Center to centers?
    Thanks Ted
    For the 80/50 what is the distance between the centers for each the heat loop side and the boiler side?
