LLH Dimensions
Uni R
Member Posts: 663
*bump*
LLH Dimensions
Does anyone have the dimensions for the two smaller Viessmann low loss headers? LxWxD with and without insulation and even more important the distance between centers for each side and the standard fitting sizes? Thanks...0 -
LLH sizes
the 80/50 H 22" W 3.1" the connections stick out 4" so overall W 11.1" connectios are 1 1/4".
the 120/80 H 36" W 4.7" The connectios stick out 4" so overall W 12.7" connections are 2"
Ted
WI. Viessmann rep.0 -
Thanks Ted - Center to centers?
Thanks Ted
For the 80/50 what is the distance between the centers for each the heat loop side and the boiler side?0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
