Tankless customer
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
that the tankless water heaters might have worked if they had been piped in a primary secondary set up. As it was all four circulators had to be calling to initiate the tankless units to fire and then as the tstats turned off one by one they would work until there was just 2 circs running, depending on which zones were left and the length of their runs. I could have repiped to the tankless units to P/S, but was concerned that if they had problems afterwards I would havve inherited problems that were not rightfully mine. The units would also trip on safety when they got near 180 degrees, and the customer would have to relite the pilots. Also the 2 pre existing boilers added up to 200,000 btu's whereas the heat load showed only 90,000 btu's were needed. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Wayco Wayne_2
    I'm working on a job
    where the pre-existing boilers were replaced by 2 tankless water heaters. The Homeowners had just moved in last Fall and never had good consistant heat. I was the 6th contractor they brought in to try and fix the problem. The house wasnt so old so I wondered why the original boilers were replaced already. I found the clue I needed to explain it in the circuit breaker panel. 2 breakers listed Hydropulse one, and Hydropulse two. Ack!! I will try to post some before pics. The system is a 4 zone hydro air system fed from the basement with an indirect for domestic hot water.
  • Ken_40
    Ken_40 Member Posts: 1,310
    Are you
    suggesting the Hydro-Pulse's are inferior, or that the current water heaters are?
    I always respected H-P boilers as the for-runner of modern condensing boilers, having installed a few and making a handsome niche market in knowing how to service those pulsers I did not install.
    Years ago, when Hydro-Therm (the maker of H-P boilers) sold and moved in with Mestek, they basically left the planet - as did the quality of the product, and replacement parts.
    Have you had bad experiences with the H-P?
  • Tony_23
    Tony_23 Member Posts: 1,033
    Me too :)
    I've still got 1/2 a dozen H-P boilers that only I will touch. Everyone else says replace them, I repair them. When the day comes that they REALLY need replacing, I'll be the one to do it. The best man to install equipment is the one who can fix it :)
    Every time I get a new "helper" in the Autumn, they are amazed at the variety of equipment I service in a single day. Gravity furnaces w/ 1925 conversion burners in the a.m. and mod/cons in the p.m. w/ a sprinkle of oil for lunch :)
    I like the copper flex lines on those water heaters...
    And, are those circs mounted with each zone valve ?
  • Wayco Wayne_2
    I've had a bad time
    with the hydropulses. Some of them have been improperly installed to be fair. Our library has had one putt putting along for years. I love hearing the very distinctive sound of the flu as I walk up at night to return books. I've seen them clog up, gas valves go bad, sparker stop sparking. condensate corrode away. It's colored my perception of them. I'm sure it's like Pit Bulls. If I took the time I could learn to love them, but,.... no.
  • Wayco Wayne_2
    Sawzall surgery
    The customer was tired of all the problems so I said I could make things work best with a repipe, and redesign. I took out one of the tankless heaters, and hung a Prestige Boiler in it's place. I then cut out the old manifold with the zone valves and wet rotor circs with their motors sticking up in the air. I repiped the remaining tankless heater so it would be in series with the indirect so they could have domestic hot water while I worked. It worked great when installed properly with good water flow. I'm almost finished. Another 4 or 5 hours to tie up loose ends and a combustion test to ice the cake. To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • Wayco Wayne_2
    Job finished
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Working great. Customer happy. Should save a bunch o money. WW
  • Mike Miller
    Mike Miller Member Posts: 22
    Nice looking job but whats with the freakin' pro-press :-), can't solder?????
  • Weezbo
    Weezbo Member Posts: 6,231
    That helped *~/:)
    looks much better now:)
  • Now Now
    Gordon and I like the Pro-Press too.
    Nice job, Wayne. The transition from hack job to mechanical perfection is stunning. Are they going to track their gas consumption this winter?
    Also, what's happening with that Trane Vapor convector job?
  • Wayco Wayne_2
    Thanks
    I can solder but why spend the time when the propress is so nice. I'm sure they will find a big difference in operating cost. I bet the wife will track it. She seems to be very organized and on top of things. Frank, On the Steam job with the Trane Convectors, I told the GC we would have to stay with Steam, but would be able to move the pipe up, and he never called me back again. My guess is the HO is willing to put up with the low pipes for now. I hope it isn't because they didnt like my answer. :( Are you going to visit The Lost Art of Steam Heating seminar in Rockville? Dans coming Oct 4th.
  • S Ebels
    S Ebels Member Posts: 2,322
    What a difference a functioning brain makes!!
    Nice job WW.
    I don't think I have ever seen a circ and a zone valve used on the same loop before. Any idea what the original installer did that for?
  • Can't make that one
    too much going on! Look for some more Solaia pics in the next couple of weeks.....
  • Wayco Wayne_2
    I can only imagine
    that is was to stop ghost flow. They may not have heard of a flo-control valve. I'm glad I got to straighten things out. (and people pay me to have all this fun, it don't seem right.) :P WW
  • clammy
    clammy Member Posts: 3,242
    great job
    What a great fix to a nightmare job ,Job looks excellent with every thing perfect, excellent show of knoweledge and craftmanship .I have seen the zone valve with a circ twice in my life and both times the guy was using it to bring the circ on through the end switch yeap and then he just jumped out the tt on the combination aquastat circ relay ,he had 3 pumps what a brain surgeon .Again excellent job the propress looks great but a little to pricey for the fittings and none of the supply house i deal with even carry any of there product line ie fitting tool peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
