Help Printing docunents
Eugene Silberstein 3
Member Posts: 1,380
When printing, go to PAGE SETUP and select LANDSCAPE as opposed to PORTRAIT.
Poof! Problem Gone!
Poof! Problem Gone!
Trying to print
When trying to print useful info from this sight, I set cut off wording to the right and I think its due to the additional adds in the main frame. My margins are set to .25 on each side. What am I doing wrong? Thanks
Mike T.0 -
Thanks Eugene:
I thought of that, but I thought I may be doing something wrong, but I guess that will work.
Mike T.0 -
Sorry for the inconvenience.
Those ads make this site possible.Retired and loving it.0 -
Another idea
Internet Exlorer is bad about that. Another option is a browser called Firefox. It's a simple, reliable browser without all the security problems of IE-and it's free. The thing I like about it is it almost always prints web pages like you see them.0 -
another solution
You can copy & paste easily enough into a text document or your word processor. Sure you'll need to clean it up a bit, but it gives you a searchable document. Name the document whatever, but a methodical naming system helps later searches. I've collected a fair chunk of good ideas that way.0 -
And still another solution...
In either Firefix or IE, use the mouse to select the text that you want to print, and then click "Print" in the browser's File Menu (as you normally would to print something). In the Print Dialog Box select "Print Selection" (it's on the left side in the Print Range Box). Only the text that you selected will print.0
- 109 Chimneys & Flues
- 972 Plumbing
- 386 Solar
- 17 Recall Announcements
