Mapp or Oxy???
Steve_35
Steve_35 Member Posts: 545
unless it's just a repair.
  • Mike C_3
    Mike C_3 Member Posts: 62
    Mapp or Oxy???
    What's you preference? For general plumbing 3/4" and 1" copper. What do you like to use?
  • bob young
    bob young Member Posts: 2,177
    \"b \" tank
    all you need is a b tank [acetylene ] & a turbo torch rig w/ two tips. good for anything from wiping a joint to brazing up to three inch and anything in between
  • Mike C_3
    Oops that's what i meant
    I meant Acetylene or Mapp.
    Does it heat quicker without getting it too hot.
    play with your heat right.
  • m dewolfe
    m dewolfe Member Posts: 92
    mapp
    I have a "b" tank for all of my bigger stuff but i do use my turbo torch an awful lot. the flame is quick and hot enough for most things and I am spoiled by the trigger spark lighter!
  • hr
    hr Member Posts: 6,106
    Should have both
    The B tank usually has a torch with interchangable heads for different size jobs.
    Also with actylene you can blend an O2 tank for silver solder jobs with a very hot tip and flame.
    And ocassional cutting torch applications.
    Mapp is handy for an easy carry and quick trip into a crawl space for a repair, etc.
    hot rod
  • Weezbo
    Weezbo Member Posts: 6,231
    B tank , heavy. mapp bottle light *~/:)
    oxy / mapp torch beacoup lighter...
    i have little pinner torches that use lighter fluid gas ...
    you might be able to braze 1/4" with it...never tried just a guess . it works on 1/2" copper sweat fitting ok. it looks like a pen sorta.
    if you check in Eugene Silbersteins section .... and search under Brazing...i think that perhaps you wonuld like the replies..
