Gas pilot nut wrench?
Bob Harper
Bob Harper Member Posts: 1,119
John L Leavey Co. Tons of goodies.
HTH
  • Ted Keane
    Ted Keane Member Posts: 11
    Gas pilot tube nut wrench?
    Does anyone know where I can get a small wrench for the pilot tube nuts on the pilot tube from the gas valves on furnaces,water heaters,boilers?Sometines the nuts are really hard to get a normal open ended wrench or pliers on.Thanks,Ted
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    I found ,
    A thin walled "flarenut wrench" at Sears a couple years back. It has a 7/16ths side and a 3/8 for thermocouples. Chris
  • jim lockard
    jim lockard Member Posts: 1,059
    Hey thats My
    Gas valve wrench Chris. 3/8 X 7/16 open end at Sears. J.Lockard
  • J.C.A._3
    Jim,
    This is a flare nut wrench, that is closed on 5 of the 6 sides.(open enough to fit over the connected tubing) Nice thing to have when you can find a thin walled version, but quite useless when some gorilla has been on any of the nuts with a channel lock or rounded it off with an adjustable wrench. Chris
  • steve pajek
    steve pajek Member Posts: 28
    pilot wrench
    its called a line wrench. its available at automotive tool supplys such as mac or snap-on
  • steve pajek
    pilot wrench
  • steve pajek
    pilot wrench
