Hybred conversion
Oil Tech
Oil Tech Member Posts: 12
A customer asked if it were possible to add a baseboard loop to his steam system. To date I have only seen one example of this, and have found nothing in print. All thoughts are welcome. thank you.
  • Oil Tech
    Hybrid conversion
    Today a customer asked if it were possible to add a baseboard loop to his steam system. To date I have seen only one example of this, and have found nothing in print. All thoughts are welcome. thank you.
  • Constantin
    Constantin Member Posts: 3,796
    Is it possible...
    ... to use a tankless coil for the base board, or does this customer have a tankless coil in use for the potable water?
  • Dale
    Dale Member Posts: 1,317
    Click left
    On the left click on heating questions and answers and select condensate heating. There are some limits of course but most cases and most oversize boilers it will work.
  • Oil Tech
    Thank you, this should be interesting, as the coil is providing domestic at this time.
