Hybred conversion
Oil Tech
Member Posts: 12
A customer asked if it were possible to add a baseboard loop to his steam system. To date I have only seen one example of this, and have found nothing in print. All thoughts are welcome. thank you.
Hybrid conversion
Today a customer asked if it were possible to add a baseboard loop to his steam system. To date I have seen only one example of this, and have found nothing in print. All thoughts are welcome. thank you.0 -
Is it possible...
... to use a tankless coil for the base board, or does this customer have a tankless coil in use for the potable water?0 -
Click left
On the left click on heating questions and answers and select condensate heating. There are some limits of course but most cases and most oversize boilers it will work.0 -
Thank you, this should be interesting, as the coil is providing domestic at this time.0
