Recirculating Pump for Every Riser
Big Ed
Member Posts: 1,117
> A contractor suggested to put a circulating pump <BR>
> for every hot water return riser then to a common <BR>
> return loop to the heater in a high end high rise <BR>
> building to better keep hot water for every one <BR>
> and thus we don't have to worry about balancing. <BR>
<BR>
Good thinking. The building would same alot of water and complaints.
Make sure the complete loop is insulated. It is code...
<BR>
Recirculating Pump for Every Return Riser
A contractor suggested to put a circulating pump for every hot water return riser then to a common return loop to the heater in a high end high rise building to better keep hot water for every one and thus we don't have to worry about balancing.0 -
I agree
Make sure the complete loop is insulated. It is code...0
- 167 Indoor-Air Quality
