Recirculating Pump for Every Riser
Big Ed
Big Ed Member Posts: 1,117
> A contractor suggested to put a circulating pump <BR>
> for every hot water return riser then to a common <BR>
> return loop to the heater in a high end high rise <BR>
> building to better keep hot water for every one <BR>
> and thus we don't have to worry about balancing. <BR>
<BR>
Good thinking. The building would same alot of water and complaints.
Make sure the complete loop is insulated. It is code...
  • Ed Garcia
    Ed Garcia Member Posts: 1
    Recirculating Pump for Every Return Riser
    A contractor suggested to put a circulating pump for every hot water return riser then to a common return loop to the heater in a high end high rise building to better keep hot water for every one and thus we don't have to worry about balancing.
  • Big Ed
    I agree
