Weil Mclain indirect boiler piping
and 1 inch supply and return . Very fast recovery too .
  • I finally got around to piping
    my Weil Gold Plus 30 indirect under my stairs . All that's left is to connect the hot pipe and take out the boiler coil . Well , stupid me , I piped the boiler supply and return into the indirect wrong . I have the supply going into the upper tapping and the return into the lower - the exact opposite the instructions call for . Hey , it was easier to pipe that way , and I was in a groove . I ran out of gas, I had a flat tire , a terrible flood , locusts ..... it wasn't my fault !
    Anyone think I should repipe the heating side ? Will I see a decrease in performance , or something worse ? Thanks in advance .
  • Tony_23
    Tony_23 Member Posts: 1,033
    Maybe
    A slight decrease in recovery, but I doubt you'll notice it, IMO. If it was my house, I'd leave it. A customer's, I'd change it so there'd never be any controversy possible.
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    OH MY GOD!!!! ,,,,MAN
    Are you nuts ..you must be out of your mind..your mental train left the station with out you....your record skiped a grove man..your six shooter fill with blanks...
    other than that you will problt losse a few degrees on reovery on start up but i bet in the long run you spend more money on coffee that what you'll waste in eff.
    send us a pic so we can put it on the wall of shame
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    I inherited a job
    The job had a pool heater that was piped by the 'other' contractor. It too was piped backwards, the goesinta was piped to the goesoutta. I mentioned it to the homeowner and he told me to leave it. It was going to be a reminder of why I'm there....
    Jeff
  • Thanks guys
    for the reassurance . I wish someone saw the look on my face when I figured out I screwed up . We installed so many TR series that I just piped it like I'm used to . DOY !
    I'm going to fill the tank up tomorrow and take a temp reading of the cold water , then see how long it takes to heat it to 125 . Of course I'll have no clue if it's a good timing unless I decide to pipe it right .
  • Floyd_17
    Floyd_17 Member Posts: 3
    What boiler...
    and what circ. pump????
    Bet you can make up the difference if you upsize the circ. a bit... if you throw a 0011 or equal on there as you would do for an Ultra, I'm bettin' you will never know the difference.
    Floyd
  • RonWHC
    RonWHC Member Posts: 232
    When the circ
    cuts off, the hottest boiler water will be left in the top of the outer tank. Could cause stacking.
  • Floyd_17
    if you had an Ultra....
    or could set the circ. to run after bit with the help of a delay relay or such you could solve that problem.
    Floyd
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    locusts...................!
    First one I did I made the same mistake. It will be fine. Just curious as to what size S/R piping & which pump?
    Robert O'Connor/NJ
  • RoosterBoy
    RoosterBoy Member Posts: 459
    You are probably the only person
    In THE WORLD to ever do That *~/:)
    Wait till the boss comes home..she will sort you out! :))
  • Update
    I just finished the piping and timed it to 13 minutes from street temp to the normal setting . That was with the boiler temp starting at the minimum in the 8124A ( 130 on the gage ) , high limit at 180 . My 18 year old niece is in the shower right now , so this'll be the ultimate test .
  • Nothing fancy
    Everything on that boiler is used except for the indirect . We come across alot of 007s , triple and dual aquastats , and expansion tanks . The indirect circ is a 007 . I'm not woried about a little loss in recovery , we have only one bath right now . I think I felt a little of the stack effect - the 1st bit of hot water out of the sink was blazing hot . I'm going to try my thermometer on it later and run it a while . Thanks Ron and Floyd .
  • David Sutton_6
    you the man !!!
    if it passes the 18 yr old girl test you got it made...
  • No boss yet
    but I have a niece that likes her hot showers . I always have a bucket and garbage bag ready in the work van in case nature calls and shes in there washing her hair for the 4th time .
