Insulation for piping
Me_8
Me_8 Member Posts: 21
Have you tried the unsplit armaflex and rubatex contact cement ? the presplit armaflex seems to be made differently and doesnt take glue or contact cement well even in low temp applications.
  • Kca_3
    Kca_3 Member Posts: 8
    Pipe insulation
    Hi Guys..
    We use armaflex type insulation for our hot water system and it works fine except that the glue that comes with the split insulation can't handle the temps. Our mitered joints also can't be glued with anything that can handle the temps. Our local supply houses don't know of anythig except rubber cement and it doesn't work either. We have a call into armaflex now but no response yet.
    Fiberglass insulation is a possibility but
    1. Put it on with dirty hands or let another trade make it dirty and it looks like S___.
    2. Cost for the install is much more.
    Any ideas?
    :-) Ken
  • hr
    hr Member Posts: 6,106
    I like this Techlite product
    it's a melamine type insulation. Available in a number of different jacket styles. I like the glossy PVC jacket.
    They don't seem to mind filling small orders.
    It should be required on all Viessmann jobs :)
    hot rod
  • jeff_51
    jeff_51 Member Posts: 545
    they make a plastic clip
    that clips on either side of the split. Think is was imcolock but was a long time ago that I used those, Real fast but maybe not as nice looking as you would like.
