Steam pressure and zones
Jim Chamberlain
Member Posts: 7
I know that the recommended settings for the steam are between .5 and 2PSI, max. I have had two plumbers tell me that, although that is true, the three mechanically operated zones we have at our church require the steam settings to be higher since the pressure drops when a zone is opened???
Is this right or should we stick with keeping pressure at the max of 2 PSI?
Jim
Jim
steam pressure and zones
I do work on a church boiler with 2 zone valves that has 2 pressuretrols they are set for 1.5 and 5 lbs system works fine boiler is controled by tstats not tomers
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
