Wood Flooring
hr
hr Member Posts: 6,106
for most of those pre finished flooring products to be sealed on all 4 sides. It sure does help if ever they get wet!
I used an Anderson brand in my in-laws. It was completely submerged one spring, for reasons we won't get into. Not even a raised grain. I believe the sealed on all sides finish is what saved my butt :) Plus the radiant heat below to quickly dry the floor.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Jed_2
    Jed_2 Member Posts: 781
    Wood Flooring
    A Contractor gave me a house plan to work up, and the finished flooring spec called for 3/4" hardwood planks from a company that had a film or coating on the underside. They guaranteed compatability with radiant heating and no distortion. I don't know the mfg's name(he's going to get it for me), but, has anyone heard of such a wood flooring? It's not engineered flooring, but real harwood, pre-finished flooring.
    Jed
  • Jed_2
    thanks, Hot Rod
    I don't keep up enough on this stuff, but clearly the "whole house" concept is advancing nicely, so it seems.
    Jed
