Wood Flooring
hr
Member Posts: 6,106
for most of those pre finished flooring products to be sealed on all 4 sides. It sure does help if ever they get wet!
I used an Anderson brand in my in-laws. It was completely submerged one spring, for reasons we won't get into. Not even a raised grain. I believe the sealed on all sides finish is what saved my butt :) Plus the radiant heat below to quickly dry the floor.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Wood Flooring
A Contractor gave me a house plan to work up, and the finished flooring spec called for 3/4" hardwood planks from a company that had a film or coating on the underside. They guaranteed compatability with radiant heating and no distortion. I don't know the mfg's name(he's going to get it for me), but, has anyone heard of such a wood flooring? It's not engineered flooring, but real harwood, pre-finished flooring.
Jed0 -
thanks, Hot Rod
I don't keep up enough on this stuff, but clearly the "whole house" concept is advancing nicely, so it seems.
Jed0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
