Pro-Press
singh
Member Posts: 866
I love mine,been using it for a month now.
I have the REMS cordless.
I also do plumbing, makes some small service jobs go much quicker.
A little diapointed about the 12V batteries, they don't seem to do many crimps,constantly swaping fresh batteries in. Buy extra.
I also bought a 2" head,but really have not have the oppurtunity to use yet.I hope to save some time on tank fill and vent installs.But I am worried about battery life with that size, one crimp per fresh battery?
Pro-Press
Just wanted to hear what you guys think about the pro-press system. Has anyone been using much of it? I would like to give it a shot, but at $1300 for the tool, I'd like to be a little more sure.0 -
great
Once you have it you will love it. I have the corded Rigid version and it is a little heavy. You may wish to look at the Rems version as its a little lighter. Best Wishes J.Lockard0 -
Rust on the tank !
I am concerned that we may forget how to solder ... no really.
Heres a couple of jobs.
Like Nike says .... Just Do It.
Scott
> ... no really.
> Like
> Scott
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 237&Step=30"_To Learn More About This
> "Find A Professional"_/A_
> I love mine,been using it for a month now. I
> have the REMS cordless. I also do plumbing,
> makes some small service jobs go much quicker. A
> fresh batteries in. Buy extra. I also bought a
Pro Press
Singh, are you talking about piping an oil tank with copper? EJW0 -
I bought the
small REMS corded version. Basic tool around $850. I bought the optional 3/8 threaded rod cutter and I REALLY like that jaw. A quick clean burr free cut!
hot rod
pro-press
Our contractors love it. Time savings, dependable & no open flames or soldering fumes. Looks very professional as well, no scorched walls or flux/solder drips. Many of our guys think it's the future of commercial copper piping.0 -
Oil tanks
I'm with EJ. Copper is not acceptable for fill and vents. I just came across the I&O manual for Granby tanks and they state almost the same thing as the current NFPA.0 -
Residential too
We are using it on everything. Love it. Neat, clean, easy. fast, what more could you want except cheaper fittings. As far as I know we are the only contractor in our backward area that's using it but even the customers are remarking how nice it looks. It definitelly makes an impression.0 -
EJW and Todd.
I have been using black iron pipe, before I purchased the 2" press head I did ask and found out code says "metal pipe" for fill and vent.Copper is metal. Many contractors,including fuel co.'s here in upstate NY use copper. I always disagreed and was taught otherwise, but it seems ok and inspectors not saying otherwise.
I'll see if I can get the exact wording for NYS residential building codes.
I love NY.0 -
Oil tank Piping
First, let me say that I think the propress is a great system. The main thing is always follow the manufacturers instructions. Granby has a great manual on their website, in section 6.3 it states"Fill or vent shall be of wrought-iron, sched 40 steel or sched 40 brass pipe" I believe that NFPA says the exact same thing but I don't have a copy in front of me. We see alot of tanks piped in copper but it doesn't make it right. I think there is confusion due to the fact that the fuel supply line(tank to burner) can be copper.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
