Hyrdronics Design Studio Question
hr
that question to Siggy. Is this the concept you are looking for?
http://www.pmengineer.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2732,132159,00.html
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
I am trying to use my new Pro version software to help in designing a system. I want to add 5 hot water coil circuits, and do not see that option under heat emitters. I was looking for a way to add a custom emitter using flow required, head, or Cv, but can't figure it out. Anybody out there who has the software, please help. I will call Siggy at Appropriate Designs, but I assume they are not open until monday.
Cosmo Valavanis
Dependable P.H.C. Inc.0 -
# of branch curcuits add
Huh? I'm sorry, I know how to add branch circuits. It's just the only options for heat emitter are baseboard, or radiant. I want to use hot water fan coils.
Cosmo Valavanis
What
Add your 5 circuits, then click show balance valves and adjust as needed.0 -
I don't know
that you have other choices.
Could you just build baseboard to the spec of the fan coil?
Say the output is 10,000 BTU/hr at 1 GPM. Insert the BTU of the FC, and adjust flow rate via the box?
hot rod
Well, I have 5 hot water coils, 90K BTU each, each coil needs 10 gpm, and per aquecoil literature, every TE4 coil itself needs 4.9 Pump head (feet), add to that about 4 ft of head for branch piping from the main. I want to design the system to use a single, variable speed circ controlled by a pressure differential sensor to maintain a constant pressure. I can figure it my old way, but was wondering how I could use my Hydronic Suite program to simulate it.
Cosmo Valavanis
Did you find it ?
I think this is close minus the vari. circ.0 -
yes, I was able to play withe the Cv ratings. Pretty cool program to play with, can't wait for some updates. Thanks for all ou help thp, and hot rod
Cosmo Valavanis
Just ordered the Design Studio,
can't wait till it gets here.0
- 133 Chimneys & Flues
- 79 Pipe Deterioration
