Hyrdronics Design Studio Question
hr
hr Posts: 6,106
that question to Siggy. Is this the concept you are looking for?
http://www.pmengineer.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2732,132159,00.html
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Cosmo_3
    Cosmo_3 Posts: 845
    I am trying to use my new Pro version software to help in designing a system. I want to add 5 hot water coil circuits, and do not see that option under heat emitters. I was looking for a way to add a custom emitter using flow required, head, or Cv, but can't figure it out. Anybody out there who has the software, please help. I will call Siggy at Appropriate Designs, but I assume they are not open until monday.
    Cosmo Valavanis
    Dependable P.H.C. Inc.
  • thp_8
    thp_8 Posts: 122
    # of branch curcuits add
  • Cosmo_3
    Cosmo_3 Posts: 845
    Huh? I'm sorry, I know how to add branch circuits. It's just the only options for heat emitter are baseboard, or radiant. I want to use hot water fan coils.
    Cosmo Valavanis
  • thp_8
    thp_8 Posts: 122
    What
    Add your 5 circuits, then click show balance valves and adjust as needed.
  • hr
    hr Posts: 6,106
    I don't know
    that you have other choices.
    Could you just build baseboard to the spec of the fan coil?
    Say the output is 10,000 BTU/hr at 1 GPM. Insert the BTU of the FC, and adjust flow rate via the box?
    hot rod
  • Cosmo_3
    Cosmo_3 Posts: 845
    Well, I have 5 hot water coils, 90K BTU each, each coil needs 10 gpm, and per aquecoil literature, every TE4 coil itself needs 4.9 Pump head (feet), add to that about 4 ft of head for branch piping from the main. I want to design the system to use a single, variable speed circ controlled by a pressure differential sensor to maintain a constant pressure. I can figure it my old way, but was wondering how I could use my Hydronic Suite program to simulate it.
    Cosmo Valavanis
  • thp_8
    thp_8 Posts: 122
    Did you find it ?
    I think this is close minus the vari. circ.
  • Cosmo_3
    Cosmo_3 Posts: 845
    yes, I was able to play withe the Cv ratings. Pretty cool program to play with, can't wait for some updates. Thanks for all ou help thp, and hot rod
    Cosmo Valavanis
  • Bob Sweet
    Bob Sweet Posts: 540
    Just ordered the Design Studio,
    can't wait till it gets here.
