Radiator Vent Broke Off
Steamhead (in transit)
Member Posts: 6,688
then run the threads in the rad with a 1/8" pipe-thread tap. Simple!
I have a radiator vent that broke off while trying to remove it. Any tricks or tools that can be used to remove the threded piece stuck in the radiator?
Thanks!
Ryan0 -
I have a radiator vent that broke off while trying to remove it. Any tricks or tools that can be used to remove the threaded piece stuck in the radiator?
Thanks!
Ryan0 -
There used to.....
Be a "radiator tool" available that had a tap, for the threade in the rads., a dye for the vents and an easy out opposite the dye for just such an occassion.
I haven't see one in a few years but I'm sure someone still makes them. Chris0 -
Easy out
Try an easy out. You can get on at the hardware store but bring along old vent so you get the right size one. EJW0 -
sometimes
I can get them out sometimes with an 1/8" easy out. But usually have to dril it.0 -
This happened to me a few months ago
Of course I wasn't prepared with the proper tools . So I sprayed some WD-40 on the threads and lightly tapped a flat head screwdriver into the middle of the hole . I turned the screwdriver ever so slightly and the piece backed right out .0 -
Beware "easy outs". I have broken the cast iron by torking too hard with one. Best to drill it out and chase the threads with a tap.
Dave in DenverThere was an error rendering this rich post.
Drill and Tap.
and have a nice day *~/:)0
