Radiator Vent Broke Off
then run the threads in the rad with a 1/8" pipe-thread tap. Simple!
  • Ryan Sarin
    Ryan Sarin Member Posts: 3
    I have a radiator vent that broke off while trying to remove it. Any tricks or tools that can be used to remove the threded piece stuck in the radiator?
    Thanks!
    Ryan
  • Ryan Sarin
    I have a radiator vent that broke off while trying to remove it. Any tricks or tools that can be used to remove the threaded piece stuck in the radiator?
    Thanks!
    Ryan
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    There used to.....
    Be a "radiator tool" available that had a tap, for the threade in the rads., a dye for the vents and an easy out opposite the dye for just such an occassion.
    I haven't see one in a few years but I'm sure someone still makes them. Chris
  • EJW
    EJW Member Posts: 321
    Easy out
    Try an easy out. You can get on at the hardware store but bring along old vent so you get the right size one. EJW
  • Dan C._2
    Dan C._2 Member Posts: 54
    sometimes
    I can get them out sometimes with an 1/8" easy out. But usually have to dril it.
  • This happened to me a few months ago
    Of course I wasn't prepared with the proper tools . So I sprayed some WD-40 on the threads and lightly tapped a flat head screwdriver into the middle of the hole . I turned the screwdriver ever so slightly and the piece backed right out .
  • Dave Stroman
    Dave Stroman Member Posts: 765
    Beware "easy outs". I have broken the cast iron by torking too hard with one. Best to drill it out and chase the threads with a tap.
    Dave in Denver
  • RoosterBoy
    RoosterBoy Member Posts: 459
    Drill and Tap.
    and have a nice day *~/:)
