A fume recuperator?
hr
Member Posts: 6,106
the Zilmet site shows these heat exchangers. HMMMM I could think of some uses for that device :)
http://www.zilmet.com/site/eng/info/sc_fumi.htm
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Looks like it can do it
like you say,keeping up on all the many aspects in an of itself is a chunk of right efforting. *~/:)0 -
Looks like
An idae that needs refinement. Like what to do it the condensate? Not to mention the particles of combustion i.e. ashes of dust etc. that'll collect in the 'wrinkles' of the inside.0 -
Fume Recuperators
It's probably intended for boiler manufacturers.
The law was changed here in April, so that only condensing boilers can be fitted. Some manufacturers had developed a range of condensing boilers ready for this. Some other manufacturers have fitted a secondary heat exchanger to their existing range to comply with the nwe law. There are apparently corrosion issues with many of these 'secondary heat exchanger' types.
I tried to get a flat expansion tank from Zilmet about a year ago, but got no response. They had made the original, but I could only get a replacement from the boiler manufacturers at about 5 times the cost of a round tank. I fitted a round tank.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
