Does anybody know where I can find......
Mike T., Swampeast MO
Member Posts: 6,928
Know they're time-tested, but you might want to check out the EPDM liners from <A href=http://www.conservationtechnology.com/>Resource Conservation Technology</A>. Very high-quality stuff, easy to use and should prove nearly eternal. They highly recommend and supply a German-made caulking to use around the flange as they claim no U.S. equivalent. Wicked expensive (for a tube of caulk) so seal off the tube with some plastic wrap under the cap.
Shower drains with screw-in brass flange that
clamps the lead down...has the weep holes already cut in? I used to be able to get them all the time...now...alll we can get are the ones with the cast iron flange and bolts. I really miss using them. The plumbers out there will know what Im talking about. Thanks guys. Mad Dog
Local plumbing house told me that they're no longer available. Only cast iron and PVC. Web search for either brass or bronze gives zero results.0 -
smith drains # 1
salsbury ,the manuf. rep. for j.r. smith got all you want. located in long island city. cash sale or through a local distributor. check the smith catalog . i will give you salsbury's # when i get to the shop. davis and warshaw is a distributor.0 -
Here's a link:
Smith Shower/Floor Drains
Surprised I didn't find it in the earlier web search. Will tell local plumbing co. They told me that others have asked as well.0 -
MAddog
Contact your local Wolverine Brass Salesman.
We purchase them all the time and keep five in stock.
Contact Wolverine Brass @ 1-800-944-9292
Scott
REally I buy a lot of WB
didn't know they still made one. Thanks Scott MD
Thank you for all the great posts guys
Mad dog
That's exactly what I was talking about Scott!
I just found it in the catalog...you agree right? the best type you ever used? Mad Dog
We use urinal strainers for any municipality that still requires a lead pan. We solder the lead to the threaded brass cup. We've been doing this for years.0 -
worth the save...
soon as you think ok now this is the type i need to be using the place goes out of business and your like better off talking to the wall ...The Wall *~/:)0 -
I use nothing else Matt
We have five or six on hand at all times.
Good Luck
Scott
Yes I've seen guys do that too
Thanks for the advice. Mad Dog
I recently had to make a double depth strainer because the inspector would not allow the tile guy to "float the strainer in the mud. We were told the shower floor was to be standard small hexagonal tile. Nobody told the plumber that "we decided to go with the granite". Where in God's green Earth am I supposed to find a deep thread strainer to screw into the darn urinal strainer that is under the granite? Simple. I took two strainers to my friend's machine shop, hacked the screen off of one, machined a socket where the screen end was, and machined off the first three threads so it would fit in the socket joint. Soldered it up and "presto", the inspector was able to sleep that night.
"Plumming are fun. But heet is neeter."
Al0 -
As nerve-wracking and annoying as it was......
I bet you enjoyed the craftsmanship and the challenge. MD
I had a ball. But I could not charge the customer for the 4 hours of machine time.
I guess education has to cost something... I honed my lathe skills.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
