gas grills
Weezbo
Weezbo Member Posts: 6,231
  • bob young
    bob young Member Posts: 2,177
    gas grills
    any gents ever convert a propane gas grill to natural gas ? what would be involved besides eliminating the l.p. regulator and replacing the orifice ?
  • Mitch_4
    Mitch_4 Member Posts: 955
    check local codes
    some places require kits (like Ontario now) Otherwise, determine the BTU required of each burner, size the NG orifice @ houseline pressure unless you are going to use a reg to 3.5" (prefeed because it eliminates pressure bounces) replace orifices, and install hose. Leak test. check burner operation (combustion test) and grill away
