gas grills
Weezbo
Member Posts: 6,231
gas grills
any gents ever convert a propane gas grill to natural gas ? what would be involved besides eliminating the l.p. regulator and replacing the orifice ?0 -
check local codes
some places require kits (like Ontario now) Otherwise, determine the BTU required of each burner, size the NG orifice @ houseline pressure unless you are going to use a reg to 3.5" (prefeed because it eliminates pressure bounces) replace orifices, and install hose. Leak test. check burner operation (combustion test) and grill away
