Hoyt Domestic Water Heater
Hello: I've faxed you what I have. Hoyt used Robertshaw gas valves. You should understand that Hoyt stopped making heaters, I believe in 1989 and that control setpoint can drift with time. It's good to look at the equipment more often than every fifteen years! For example, I would not expect a relief valve that hadn't been tested for 15 years to perform reliably.
Yours, Larry
  • Hoyt Water Heater
    Does anyone know where I might be able to get an installation and operations manual for a 1980 vintage Hoyt Residential gas fired domestic water heater?
    Any assistance would be appreciated
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,011
    Yes, but...
    Hello: I collect the old installation manuals, but what info are you looking for? There are not a lot of differences in installation and operation with conventional residential gas heaters. I do suggest you have a look at that heater's anode and relief valve!
    Yours, Larry
  • Hi Larry,
    I would like to see the entire manual. In particular I am interested in any information relative to the thermostat setpoints, and discussion on hot water temperatures and setpoints.
  • Larry,
    I would greatly apreciate it if you could fax me a copy of the Hoyt manual! My fax number is 310-915-6107.
    Dave
  • Thanks Larry!
    I have checked the heater and it seems to be working perfectly. However, the owner claims that the water,at times, is excessively hot. They keep it at the normal setpoint, and I have consistently recorded a pretty steady 130 degrees F with 100% hw. The owners seem to think the temperature spikes at times.
    Any thoughts?
    Dave
  • Larry Weingarten
    look to the plumbing...
    ...first for variable temperatures. Anything that alters flow, like other water draws, or the hot/cold mix, like cross connections or a hot recirc line, can affect the delivered temperature. I can be of more use to you once I know a bit more about the system.
    Yours, Larry
