special tools
Chop saw, air compressors, staplers, test rigs of all sorts, cordless tools of every description, stud finders, electronic measuring tools, laser levels, stair climber, portable threading gear, wrenches of every description and size, digital camera and lap top, in-the vehicle-fax machine, and the list goes on and on.......
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • hydronics tool box
    What sort of special tools do you keep or amassed in the art of hydronic installations including radiant installs. Here are some of my new stuff in the last 5 years or so...
    pex uncoiler
    dead blow hammers, for hitting pex into grooves
    router & template guides (warmboard installs)
    pex cutters
    pex reamers
    glycol pump made from a shallow well pump w/ presure switch turned down to 25psi and check valve;
    clip gun
    cable staple gun for t-stat wire
    refractometer to check levels of glycol
    manometer for nat gas
    fyrerite pro 125 combustion gas anlyzer
    I will check back after I go through my shop
    Don
  • Geo_5
    Geo_5 Member Posts: 69
    pex reamers
    What is a pex Reamer?,if it's that tool that removes the first layer of PAP,yup got one,if not what does it do?.
