special tools
Al Letellier_9
Member Posts: 929
Chop saw, air compressors, staplers, test rigs of all sorts, cordless tools of every description, stud finders, electronic measuring tools, laser levels, stair climber, portable threading gear, wrenches of every description and size, digital camera and lap top, in-the vehicle-fax machine, and the list goes on and on.......
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hydronics tool box
What sort of special tools do you keep or amassed in the art of hydronic installations including radiant installs. Here are some of my new stuff in the last 5 years or so...
pex uncoiler
dead blow hammers, for hitting pex into grooves
router & template guides (warmboard installs)
pex cutters
pex reamers
glycol pump made from a shallow well pump w/ presure switch turned down to 25psi and check valve;
clip gun
cable staple gun for t-stat wire
refractometer to check levels of glycol
manometer for nat gas
fyrerite pro 125 combustion gas anlyzer
I will check back after I go through my shop
Don0 -
pex reamers
What is a pex Reamer?,if it's that tool that removes the first layer of PAP,yup got one,if not what does it do?.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
