Storage tanks for Solar
Kevin_in_Denver_2
Member Posts: 588
Where do you get something like that? Mass-produced water heaters only go up to 120 gallons, and the 80 gallon units are a better value at over $4.00 per gallon vs. $6
Pressure rated tanks are definitely preferable, because you can keep the system closed.
Any ideas?
Any ideas?
How much
do you want to spend? How nice of a tank?
Lochinvar, for one, has nice insulated steel, glass lined, storage tanks, up to 500 gallon I believe.
I bought a used 500 gallon LP tank for $350 recently. Siggy often uses (lp tanks) in his designs for solar and wood boiler storage as they are ASME pressure rated. I suspect he specs new ones
Of course you would need to add an insulation package to that.
I've also looked at the HDPE tanks that you see at farm stores and as septic tanks. Non pressurized and limited to 150° temperatures. However they are very inexpensive for the capacity. Some have large man holes to allow easy HX coil installation.
hot rod
LP tanks are a good idea
I can just hear my building dept. asking if they are rated for water usage.There was an error rendering this rich post.
The label
that is welded on mine, which also have a UL stamp, state 250 psi max water pressure and 650°F max temperature.
The ASME stamp is a U not an H like on boilers. Guess it would be best to check with the local AHJ and the tank manufacture for a copy of the listings.
hot rod
