Online Energy calculator
singh
Member Posts: 866
RPA site.
Information tab -then free software download.
Does anyone
know of an on line energy calculator for HVAC that I could recommend to homeownwers. I did a google search yesterday and found little. It seems to me it would be a good tool for educating customers of the benefits of high efficiency. WW
Interesting
It makes comparisons by a Million BTU's for each fuel. Heat Pumps look real good but how can you tell when they switch over to back up heat wat the real savings are? WW
Thank you
Alan. This is important stuff to understand and compare.
Maybe
they don't want you to know that......0 -
I finally figured out my Wrightsoft
software. There was a field that needed to be changed to get the accurate heat pump prices with fossel fuel backup. A typical house with 3 ton cooling load and 65000 btu heating load can save 500 a year using a heat pump on top of their 80% furnace. If you upgrade the furnace to 90% nstead you will save about 300 per year. If you do both you will save about 700 per year.
- 167 Indoor-Air Quality
