Spiro Agnew
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
my Spiro Agnew trashcan. A shame he was from Maryland. He was a maroon. His burnt marshmellow speech proved it. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • hr
    hr Member Posts: 6,106
    Oh, I mean Spiro Therm
    has finally resigned :) to the fact hydronicians in this country like to solder things together. A sweat version of the JS, 3/4- 2" in now avaiable. Yeah!!!
    Does it read that the vertical series is available in sweat also? If so, I would be the happiest plumber around.
    I've always like the ability to screw a FIP pex adapter on the vent nose and pipe it out of harms way. I hated threading copper to mip adapters into the unit however, in fact I would usually sweat the threaded connection also.
    No more. Thanks Spiro :)
    PS, think ProPress also
    hot rod
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    alright, good job
    So you got the Greek to look.....
    Yeah, it is good news about the solder fittings, but I have'nt tried soldering one yet. Why solder the thread? I assume you are using two male adapters anyway?
    Cosmo Valavanis
    Dependable P.H.C. Inc.
  • Dave Yates (PAH)
    Dave Yates (PAH) Member Posts: 2,162
    You forgot
    the T
    Somewhere, tucked away in a box, I have a RM Nixon & ST Agnew set of candles. I had much longer hair in those days(G).
  • hr
    Ever see
    what glycol does to that copper to brass threaded connection? Don't know that I have ever seen a glycoled Spiro that wasn't green, and weepy around the threads. I KNOW solder holds glycol at bay :)
    hot rod
  • Dave Yates (PAH)
    If memory serves
    I'll find a George McGovern for Prez pin stuck in the Nixon candle(g).
    I read a poem at my graduation from high school. Short & to the point. If only I'd known..... It went like this: "I was always afraid of being a radical when young for fear of being conservative when old." It was by Robert Frost (I think).
    Steamhead Member Posts: 18,211
    The tradition continues
    Agnew, Mandel and others.... and Ed Norris now has a talk show in Baltimore, he's Maryland's answer to G. Gordon Liddy.
    Consulting
  • Bob Sweet
    Bob Sweet Member Posts: 540
    hr when you thread the copper MIP
    into the spiro,I assume it's not doped or taped before soldering?
  • dbx_2
    dbx_2 Member Posts: 2
    Solder Flux
    I have been able to find my favorite brand of solder flux for a while now. (Thunder Bolt) So, my question is, what is your favorite brand of solder flux?
    Thanks...!!!
  • Cosmo_3
    fav flux
    I have been using Oatey #5 for a long time now, so far I have not had a reason to change, can't beat that sodium chloride for a nice neat joint, and you can always go back after soldering to adust a joint is need be without taking everything apart. I only use this stuff on hydronic work.
    When working on potable plumbing work I use Oatey's water soluble stuff, as long as you know how to solder correctly without burning every fitting it is a good flux. But boy that sodium chloride is soo much easier to work with......
    Cosmo Valavanis
  • pitman9
    pitman9 Member Posts: 74
    Do you mean zinc chloride?
    The sodium chloride around here is salt. :)
  • Cosmo_3
    your right
    Just installed a softener today.... I guess I was still smellin' the salts!!!
    OOPS!
    Cosmo Valavanis
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    Comical politicians
    Remember the Nattering Nabobs of Negativism? What about Bebe Rebozo? whatever became of him? By the way; does a low loss header alleviate the need for a air removal device in line?
