hot water recirc line
bob young
Member Posts: 2,177
the return goes into the cold supply before the coil with a check valve , pump & aquastat and of course control valves
New boiler installation. Existing boiler has a tankless coil with with gravity/natural convection recirc line. My question is when replacing the boiler do I tee the recirc. line into the mixed side of the tempering valve or directly from the hot side of the tankless coil. No money in job to install pump.0 -
Does this look right?
Thanks for your help0 -
could not open attach. ???0 -
circ. line
looks o.k. but i have always made the connection into the main trunk line not the branch . don't know if it matters maybe one of the other pro's will comment on that. we always use a pump & aqustat . on the cold connection to the mixing valve we drop the cold connection 27" below the inlet to form a heat sink.0
- 167 Indoor-Air Quality
