tube spacing?
Andy_14
Member Posts: 121
1/2" Safelink/Mr.Pex PAP. Thanks
Is there any down side to 6" OC spacing in a concrete slab install besides extra tube cost? Even though 6"oc is not needed.0 -
More manifold ports!
more ties Less space for concrete
Seriously though, 6" OC will make for a nice even floor temperature spread. Probably quicker response. Possibly lower supply temperatures. What diameter tube will you use. 6" OC loop ends with 1/2 can be a challange. 3/8 will require shorter loop lengths and more loops and manifold ports.
hot rod
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
