tube spacing?
Andy_14
Member Posts: 121
1/2" Safelink/Mr.Pex PAP. Thanks
Is there any down side to 6" OC spacing in a concrete slab install besides extra tube cost? Even though 6"oc is not needed.0 -
More manifold ports!
more tiesLess space for concrete
Seriously though, 6" OC will make for a nice even floor temperature spread. Probably quicker response. Possibly lower supply temperatures. What diameter tube will you use. 6" OC loop ends with 1/2 can be a challange. 3/8 will require shorter loop lengths and more loops and manifold ports.
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
